was able to get my qt50 started by pouring fuel through a funnel into the line, but for the tank I can't get the round cap off. I have tried using carb cleaner to maybe unstick it but it isn't working. Not sure if this is a common problem
Can't simply press down and turn the cap left ?
Rubber washer under the cap has degraded and "welded" it to the tank.
Common problem with today's fuel.
Big channel lock pliers should get it.
And you need a new washer.
Spray the flange and washer with a lubricant before the first twist.
Gasket, Cap
3T5-24612-20-00
$3.95
