Re: Puch E50 timing
Robert Parr /
so you set the point gap at TDC and then measure over as Ken suggest 17mm and make a mark on the fly wheel then when the 17mm mark lines up with the TDC mark your points should just start to open which is referred to as your firing mark...correct?
