so do you set your points at TDC or 17^ BTD
Btdc
Here comes the piston & Boom.
Compression that shit and squeeze it into the smallest fucking area.
You want to have the flywheel set to where your points are at their most open when you set the point gap, which is a little past TDC.
excuse me BTDC
are you correcting me or is that where you should set them?
I guess what ever that means is suppose to be funny or what ever.
It does not make any sense to me?
You set the points with the piston at just past TDC...
I didn’t write this but somebody posted it with some words I told him about finding top dead center, timing and keeping engine cool
It may be helpful
> Robert Parr Wrote:
> excuse me BTDC
Both. If you're settling timing which is where your points are supposed to fire at you set them to begin to open at BTDC. If you're setting the points gap you set them at TDC or . Read the write up Ken posted and you'll understand.
Set gap at TDC. Timing is set BTDC
so you set the point gap at TDC and then measure over as Ken suggest 17mm and make a mark on the fly wheel then when the 17mm mark lines up with the TDC mark your points should just start to open which is referred to as your firing mark...correct?
If you can't understand, find someone who can help you.
finally got it, I was reading ken's post wrong for the last couple of years, travis and his you tube video set me straight....off and running :)
and by the way guys thanks for all your help
Lol, nice!
nice one! I learned to time e50’s from travis YouTube also!
