karkoma petcock rubber seal
gener hernandez /
greetings friends,can anybody please help me find a replacement petcock rubber seal for a sachs karkoma petcock,i checked with myrons they dont have it anymore,thanks and regards
Re: karkoma petcock rubber seal
Brad William /
These are a 10 dollar must-have set of punches for any/all gasket work.
https://www.harborfreight.com/9-piece-hollow-punch-set-3838.html
The set I got 10 yrs ago had a couple of larger sizes up to one inch.
In five minutes I knocked out a pair of the four hole petcock seals from the lid of a 5gal poly pail with these punches. Much improved over soft rubber orig. No leak and haven't worn out in many years. (edited)
the bucket top is a good idea.
The punch set is a good idea . ;)
The repairing rather than replacing the petcock is a good idea.
The new ones I bought have white nylon seals. So I measured the OD 10mms and ID 7mms. Now I'm on the hunt for nylon tubing to cut to size. When taking the petcock off to clean, that washer is mashed. So hoping just to use the home made one.
