I have a Magnum MKII LTD that has been running well for a few months now; yesterday when I started the bike it was idling a little faster then I feel it had in the past. Not to mention, when I turned the throttle it died. Went to check the plug and it was quite blackened with an oily deposit on it so I switched out the plug with a fresh one and now it won't start at all. I haven't looked into it too much, since it was late in the evening yesterday, but having some points to go off too would be great. I will be checking the fuel line today to see if it's flowing properly; the oil reservoir was visibly at a level that was marked as adequate. I have not checked if it is sparking or not anymore. What are parts on the bike that might be causing this issue if they have failed?
