Re: Fuel not getting to the spark plug
Aaron Hilf /
> ♣Slew Foot♣ Wrote:
> when you turn it over with the plug in it do you hear a whooshing sound
> if you do you're probably have either a case leak or a seal leak the
> seal leak usually is sucking in air and it stops the motor from
> developing the low pressure needed to open the valves in other words
> your moped doesn't suck right
Thanks for the input. I'll turn it over a few times later today and see if I hear a whoosh or not. I don't think I've heard a distinguished whoosh but I'll listen for it today and see.
When you say 'seal leak' -- are you referring to the main seal? Crank seal? All of the above? Apologies if this is a dumb question -- pretty new here. Thanks much.
