Re: Fuel not getting to the spark plug
Garelli Master✨ /
> Aaron Hilf Wrote:
> Update — Swapped the main jet from the broken card into the new one. It
> isn’t stamped, so I’m not sure if it was the right size.
> Sprayed some premix into the spark plug hole and tried to start it up.
> Still nothing.
> I assumed it would start for a few seconds with fuel directly into the
> plug hole. Any reasons why it still wouldn’t?
> Thanks in advance for any help.
Does it feel like it has compression? You probably need to pull the top end at this point.
