Re: NC50 Oil in Combustion Chamber / Leaks from Exhaust
Born to be WillD /
yeah chances are if it had an oil injector that the seals failed and dumped the oil into the case and exhaust. you can run it to flush it maybe. same thing can kinda happen if gas leaked past the float seal and filled everything up and just slowly thickened as it evaporates
