Jawa 207 Swingarm + Swingarm Bolt Removal
Sasha T /
This is my first post on the forum. I am rebuilding my dad's 1977 Jawa Babetta 207 (Transistor 40). I've disassembled the entire bike and I'm having trouble removing the swingarm bolt. I've removed the rubber inserts (the old burn out 'em way) and I've tried several methods to push the swingarm bolt through the frame. I'm wondering if this bolt is pressed into the frame or there is some internal pin preventing it from pushing through. I've heated it up with a map gas burner for over 10 minutes, applied all sorts of lube and solvents, and it won't budge. Is there a trick to removal of thw swingarm? Any help is greatly appreciated!
