Broken exhaust stud
Finn Thor Heyer /
Hi everybody,
So recently one of my exhaust studs has rusted through and broke off.
I got the rest of the stud out of my cilinder but all the replacements are wayy too
expensive here. I was wondering if i could use a long stud from the hardware store like this one; https://www.gamma.nl/assortiment/gamma-draadeind-rvs-m6-x-1000-mm/p/B450528, cut it up, and just use it like that. Would that be a good idea?
Re: Broken exhaust stud
Dirty30 Dillon /
Just use an M6 cap head bolt if they're too expensive.
Threaded rod is bad news, in terms of stretching
Finn Thor Heyer /
do you think a threaded rod will stretch more than the standard exhaust studs?
Dirty30 Dillon /
> studs?
Absolutely, it is not hardened. Use a M6 cap bolt.
Finn Thor Heyer /
what about cutting the top of a bolt and use that?
Dirty30 Dillon /
By the time you buy a tap to chase the threads for this home made stud, and the bolt itself, you could have purchased a stud.
You seem to be deadset on using a stud. Maybe just buying one would give you what you're looking for.
https://www.puchshop.de/stud-m6.html?search=stud
Finn Thor Heyer /
i was looking at those yeah, but the problem is that
alluminium will rot away faster when i use ss studs or just normal steel studs.
it has to do with the nobility of the metals. Galvanized bolts are steel with a
layer of zinc. Now that zinc is less noble then alluminium it should degrade faster am i right?
just use a bolt w a washer allen head if theres no space and change every 3 yrs b4 it rusts out.
dude it doesn't have to be so complicated. Dirty D gave you various options.
♣Slew Foot♣ /
Brass compression thread...star lockwasher it will flex and give and when it does go it is easy to fix...
Brad William /
https://www.google.com/search?q=honda+civic+%226mm%22+stud&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=2ahUKEwixiZO6o5HiAhVIeawKHctoDEIQ_AUoAnoECA0QAg&biw=320&bih=490#imgrc=yMvBaroJWybpjM
Honda Civic manifold stud. Any parts store on the planet should have em in stock, no?
Is something like this really more than a few USD equiv where you are? Otherwise, +++ on the 6mm black oxide Allen head bolt. 10.9 grade or so. Get a few longish ones, 50mm 'bout. Don't need a die to chase the cut thread. Thread a nut on the good side and when it comes off the cut side it'll align the thread good enough. Wire wheel the rest if needed. (edited)
Brad William /
...better link
https://www.kseriesparts.com/HON-90041-PA5-000.html
6mm X 28mm (edited)
Brad William /
And these make excellent nuts for the exhaust studs when you can find them.
Brass 6mm "standoffs" or "threaded rod connectors".
Extended flats are easy to get to with a socket and engage lots of thread without fear of stripping. (edited)
I just got schooled in Metal Hierarchy by reading this thread. Thank you. Who knew studs were so complicated....
