Re: Puch Maxi connection rod bush to bearing?
Henrik Andersen /
> Moped Lar (OFMC) Wrote:
> You cannot just swap it out. You’d have to ream out the connecting rod
> to accommodate the larger needle bearing. Doing this is not advised as
> it will weaken the rod.
Ok. Is it a idea to change the bushing when fitting a new cylinder? If, how is this done?
