Re: Puch clutch ( I think ) issue
Nick MBC /
> Saabsonettguy . Wrote:
> It sounds like the motor isn't starting from your description.
This is true. It likely has nothing to do with the clutch.
When you're turning the bike over using the clutch it's firing but not running (or else it would keep running after you let go of the clutch). I'd check your spark, carb, and timing in that order
