Puch clutch ( I think ) issue
Ryan Cook /
Having a problem with a Puch clutch ( I think it's the clutch at least ). Will need some help diagnosing though.
Pedal start works fine but when you let go of the clutch lever the engine stops, recently changed the oil in it so have a feeling this might be the cause of the problem as this never occurred before that.
Changed from 5w30 to ATF fluid aqm
