Google was no help, nothing appropriate in the wiki.
I need a diagram for the M01 that excludes brake light switches, preferably keeps the lights independent of each other and uses only a one 3-contact terminal block.
Thank you for your time!!
So you don't want brake light switches? Do you want running light switch?
Get a pencil and paper . Draw what you want . There , you have a wiring diagram . ;)
Stephen, I want a running light that is hard wired to be on. No switch needed.
You should be able to find that out on your own.
> needed.
How many wires coming out of your stator?
Stephen, there are three, green/black/red. I tried the service manual but the diagram has paths I just can't wrap my head around.
Al,
Here is a simplified Morini wiring diagram that may help. http://www.thewanderingpacer.com/download/41/manuals/2931/morini-franco-pacer-moped-wiring-diagram-courtesy-of-shelly-mopedgal.pdf
Looking for one that excludes the brake light switches, it makes a difference apparently.
> Benjamin The Wandering Pacer Wrote:
> Al,
Ben,thanks to you and Shelly Mopedgal for that info on wiring. I bookmarked it.
