Benelli Blazar Brake Shoes
Wondering if anyone could help me identify what brake shoes I could replace these with.
Re: Benelli Blazar Brake Shoes
Looks like the standard 90x18 shoes.
looks like tomos, measure in mm.
Gotta be right on the width.
width does matter also the 20mm wide ones won't always fit where 18 is required, I agree it looks like standard 90x18, that's a common size, here are some:
https://www.treatland.tv/treatland-s-SUPER-HIGH-QUALITY-brake-shoes-90x18-p/groovy-pads-16135-90x18-q.htm
worth also checking the pin size but I expect that'll be your typical wheel. The brake pads vary by the wheel manufacturer not the bike so much, instead of searching benelli blazar brake pads, look at the wheel id it a grimeca snowflake wheel? Leilu spokes? but yea, better than that is measuring, which you've done, and it's 90mm, probably 90x18 wide, so get those, rip, stop, party.
Yea even though those come with a horse shoe spring you can use either of style spring.
Actually those shoes look a lot better than most.
I like to use the o.g. springs anyways, unless they're rusty or broken.
