Re: Puch 1977 - Hard to Start // Revs High // Stalls
P D /
I'd take the burrs off that slide pin .
And , that throttle is definitely not right .
I'm not familiar with either the carb or the throttle , so I'm not much good for specifics .
You might consider taking the throttle tube off the bar and cleaning the inside , the cable catch /race , the housing inside and the bar . Then apply a dry graphite based lube to all friction surfaces , including the cable . Use enough lube in the cable until you see it coming out the other end .
  Puch 1977 - Hard to Start // Revs High // StallsTopic by: Tyler Durphine Tyler Durphine 04/22/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 08:28PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 08:56PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 09:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 09:20PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:33PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:46PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 10:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: pat splat pat splat 04/23/19 01:36PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 02:25PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Alex Fredericksen Alex Fredericksen 04/23/19 04:54PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:29PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 12:18PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 12:27PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 02:12PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 03:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 03:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 04:59PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 05:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 07:37PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:31PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:39PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:40PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:49PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:53PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 08:58PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 09:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 09:50PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:11PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:25PM
