Re: Puch 1977 - Hard to Start // Revs High // Stalls
Tyler Durphine /
Also. When I removed the carb I feel like I screwed up the throttle cable. It moves with the air filter off you can see the slide in the carb move properly however the throttle isn’t super smooth ant the grip and doesn’t have a super clean snap back. Very slow and seems to only go back maybe 80-90 percent. Goes back when I move it manually and I also hold it closed when starting.
Having a hard time finding info on adjusting the throttle cable. Seems loose too me as the nuts and threaded sleeve just kind of hang near the throttle assembly on the bars - as if they don’t do anything. The cable itself just rests in the slot but if I pull it I could unseat it. (Photo after I pulled it out pretty easily) not sure if that’s normal or not.
  Puch 1977 - Hard to Start // Revs High // StallsTopic by: Tyler Durphine Tyler Durphine 04/22/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 08:28PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 08:56PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 09:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 09:20PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:33PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:46PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 10:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: pat splat pat splat 04/23/19 01:36PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 02:25PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Alex Fredericksen Alex Fredericksen 04/23/19 04:54PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:29PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 12:18PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 12:27PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 02:12PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 03:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 03:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 04:59PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 05:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 07:37PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:31PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:39PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:40PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:49PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:53PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 08:58PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 09:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 09:50PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:11PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:25PM
