Re: Puch 1977 - Hard to Start // Revs High // Stalls
Mike Boyd /
Notch shouldn't be an issue unless it's causing the slide to stick. You should try maybe going up or down one size on the pilot once you get it running. What size jets are in there now?
The high revving could be from stuck open slide or from an air leak. If the slide isn't sticking open and you can't check for air leaks at idle because it won't idle, your options (in my opinion) are:
-mock up a leakdown tester and check for leaks that way (search function to find out how)
-Open up the magneto cover and see if there is any seepage coming from the seal behind the stator plate. If not, GENTLY tighten down the cylinder stud and intake nuts and carb mating clamp (check that the plastic shim is in there) and see if the situation improves, and if not order a new gasket set for the kit and maybe new seals for the crank
  Puch 1977 - Hard to Start // Revs High // StallsTopic by: Tyler Durphine Tyler Durphine 04/22/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 08:28PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 08:56PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 09:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 09:20PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:33PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:46PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 10:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: pat splat pat splat 04/23/19 01:36PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 02:25PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Alex Fredericksen Alex Fredericksen 04/23/19 04:54PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:29PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 12:18PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 12:27PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 02:12PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 03:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 03:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 04:59PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 05:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 07:37PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:31PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:39PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:40PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:49PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:53PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 08:58PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 09:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 09:50PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:11PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:25PM
