Re: Puch 1977 - Hard to Start // Revs High // Stalls
Mike Boyd /
Lubricate the throttle cable, it may be sticking in a position with the throttle slide open. When you see a throttle slide with that notch in it it can mean that the carb wasn't tuned correctly on the pilot jet, and to compensate the idle screw was hogged down all the way.
Also sounds like maybe an air leak or blown seal situation. Hard to say for sure, if you can get it to idle you should check for air leaks
  Puch 1977 - Hard to Start // Revs High // StallsTopic by: Tyler Durphine Tyler Durphine 04/22/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 08:28PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 08:56PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/22/19 09:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 09:20PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:33PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:46PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/22/19 09:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: P D P D 04/22/19 10:02PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: pat splat pat splat 04/23/19 01:36PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 02:25PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Alex Fredericksen Alex Fredericksen 04/23/19 04:54PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:29PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 12:18PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 12:27PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 02:12PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Seth B Seth B 04/24/19 03:42PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 03:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 04:59PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 05:14PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 06:47PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/23/19 07:37PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:31PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:39PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:40PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 07:49PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 08:53PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 08:58PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 09:13PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Mike Boyd Mike Boyd 04/24/19 09:50PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Daniel '' Daniel '' 04/24/19 10:09PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:11PM
  Re: Puch 1977 - Hard to Start // Revs High // StallsRe: Tyler Durphine Tyler Durphine 04/24/19 10:25PM
