charge coil in the stator is usually the problem but try taking your spark plug boot off and cutting 1/4" of the ignition coil off to get back to good wire. screw boot on and see if that helps.
Subject | Written By | Posted |
Qt50 ignition coilTopic by: Fred Sons | Fred Sons | 04/22/19 08:19AM |
Re: Qt50 ignition coilRe: Jack Rutherford | Jack Rutherford | 04/22/19 08:59AM |
Re: Qt50 ignition coilRe: Piston Port | Piston Port | 04/24/19 01:18AM |
Re: Qt50 ignition coilRe: Den 23 | Den 23 | 04/26/19 10:12PM |
Re: Qt50 ignition coilRe: Louis Brunskill | Louis Brunskill | 04/30/19 04:51PM |
