Re: Sachs 505 Clutch Issues
Born to be WillD /
there's a small amount of axial play but it's held in place by the spring washers. you can't really detect it pressing or poking by hand but with the bike running and lube warmed up between the pads and plates and the significant leverage of a stopped wheel holding things in the back half you get a smooth steady slipping at idle (ideally)
you can't see it really but I bet if you tried pulling the starter lever while watching you'd see the little additional compression to where it's fully engaged during starting vs the expected axial play you're not seeing just staring at it.
