brutal. I feel your pain. best of luck
Also, I had mopedcrankworks do two for me with Rito conrods, roller bearing on the smallend too, definitely helps with higher RPM. And only like 75 bucks, which is less than the bearings and seals will run ya. though I usually just gear up on a ZA and let the transmission take care of lowend and keep rpm lower up top.
