Re: Checking for spark on 1978 Bravo
Born to be WillD /
You wanna make sure you turn the right direction. And that the kill switch is on run. Take out the plug, still in the boot, lay it on the engine so the metal is in contact with metal. Spin the flywheel with the drill. You can remove the belt so it's not trying to spin the rear wheel while ya check. If no spark, try prying the little cover off the ignition so you can reach in and 1st make sure the points open at the right timing, and if that's good, but no spark - clean the points
Details of the how to, read thru Fred's guide in the wiki
