Re: she wants a ring?
P D /
> kenny s Wrote:
> its not always that easy. some pistons only have one ring. also im not
> sure if its possible to put on the ring upside down. Also its
> recommended to replace the ring every time you take out the piston from
> the cylinder. also if the ring isn't aligned with the dot it would
> probably break.
In what world would anyone replace rings every time a cylinder was removed ? Not even racers do that .
And , there are no dots to align with . There are locator pins that the ring has to mess with .
