Re: she wants a ring?
Seth B /
An FG ring won't go on properly upside down as the pin is offset in the groove. It would not be able to compress enough to insert into the cylinder without breaking the ring ends.
Nobody replaces the ring every time the cylinder is removed, except racers.
And if you don't line up the pin with the ring ends, you bet it'll bust.
