Re: she wants a ring?
kenny s /
its not always that easy. some pistons only have one ring. also im not sure if its possible to put on the ring upside down. Also its recommended to replace the ring every time you take out the piston from the cylinder. also if the ring isn't aligned with the dot it would probably break.
