Re: Tomos A3 with 35/55 stator&flywheel with parmakit cdi
Matthew Fickett /
So I’m clear,
> 1. Piston stop find tdc
> 2. Mark flywheel and case anyplace at the same location.
> 3. Timing light and these marks should line up if timing is correct
> minus the 2.5mm btdc. (Treats gave me a 2.5mm for better temps.) so
> before tdc, measure over 2.5mm and when set correctly the marks should
> line up
> Am I getting this right? Lol
> What treats told me...
> “The box has a 7 degree timing curve so If you're timing your tomos to
> fire at 1.8mm BTDC at wide open throttle then you would want t o set is
> a 2.5mm BTDC. This will give you better over all temps and performance.
> -Dana“
