Puch Maxi Real Troubles
Craig Rodgers III /
Hey guys, so I'm having trouble with my 1976 Puch Maxi Nostalgia. Here's my setup:
50cc stock e50 motor
12mm Bing with stock atomizer and 76 jet
Techno bullet pipe
Metal mesh air filter
New k star 50cc piston and rings
Everything else stock except for rear shocks and seat
So the trouble is i cant get it to start. Ive looked at Fred's guide over and over. The timig is set perfectly, I have 110 compression, a bright blue spark, and fuel running to the motor. A couple months ago in the cold I would ride this thing every day and put some real miles on it, now that it warmed up and I down jetted one size it will not run at all, any thoughts?
Re: Puch Maxi Real Troubles
Probably Fred /
Always use choke when starting
Maybe Blocked filter in banjo fitting in carb, blocked fuel flow somewhere or air leak
Put a bit of gas in cylinder through plug hole and try kicking over
Craig Rodgers III /
Thanks for the reply, I actually just tried that today I was thinking that starting fluid might make things a little easier but I'm not sure
derek from black pipes moped gang 🌧 /
How did you determine that you’re getting fuel to the engine?
Craig Rodgers III /
To be honest I'm not super sure I've adjusted and cleaned and cleaned my carb
Richard Eberline /
62 jet
217 atomizer
any needle position 3 from top
.020 plug gap
.008 air gap
.017 point gap
17 btdc timing
Ye olde crank seal under magneto?
Pull the plug out after trying to start it and see if it’s wet with gas. If it isn’t the problem could be your crank seals.
Craig Rodgers III /
I put the plug in kicked it over and then pulled the plug, it is wet afterward but still won't start
Make sure you have fresh fuel.
Craig Rodgers III /
Yep, fresh fuel mixed to exactly 50:50
^^ I assume you mean 50:1, not 50:50?
Craig Rodgers III /
Yeah that's what I meant
Craig Rodgers III /
Yeah that's what I meant, 50:1
♣Slew Foot♣ /
Check your horn wires, holding your front brake when you start it if it starts there's something wrong in the electrical
Craig Rodgers III /
Hey guys so update:
I brought the moped home from college, literally first kick and it started up, ran, and I rode it all day. Not really sure why it won't run at college which is like 45 minutes from my house where it does run
> Craig Rodgers III Wrote:
> Hey guys so update:
Im thinking you have a intermittent electrical issue or a fouled plug.
Bill Mazzacane /
Not related to your problem, but your oil mixture was so lean.
your engine will produce more HP, with less engine wear when you run a richer oil mixture. 24:1 as a minimum, but 20:1 is preferred using a high quality MX oil.
Bill M.
20:1 ? That’s whack.
50:1 is fine
kevin Smellaflange /
try to run 40:1 Am-sol synthetic... when did you put on the chamber? ..does this bike have a quirky tail light grounding problem.
shoot a little ether to detect leaks.
> Hey guys so update:
perfect excuse to skip class
Craig Rodgers III /
How to adjust air gap
