Re: !!! HELP !!! 2009 Tomos A55 Streetmate R Bogging down when any throttle
Mike George /
Hey,
Check out this thread: https://mopedarmy.com/forums/read.php?6,4234027
Sometimes Tomos flywheels like to eat the woodruff key on the crank and the timing goes out of whack.
Grab a flywheel puller if you don't have one and check the inside surface, compare it to the pictures in the thread I linked, maybe you have the same thing going on.
https://www.treatland.tv/ProductDetails.asp?ProductCode=puch-bosch-flywheel-puller
If you go this route you might want one of these too, especially if this ends up being the problem, you'll need something to hold the flywheel while tightening it back up after lapping:
https://www.amazon.com/dp/B01N1LJDZH/
(edited)
