!!! HELP !!! 2009 Tomos A55 Streetmate R Bogging down when any throttle
Mike A /
Hey guys.
I'm in dire need of help. I have a 2009 StreetMate R with an A55
moped is bone stock. I'm all of a sudden having an issue with it bogging down
when I give it any throttle.
It will fire right up on the first kick and idle just fine.
But when I give it any throttle,It bogg down, and sometimes will even stall out.
So far... I have checked for air leaks on the Carburetor....nothing... even replaced the carburetor with a brand new one
-Intake and airbox.... Nothing
I have even checked the Head... None that I'm aware of.
I have check for clogged fuel lines and even replaced the filter...
Note: I do have a minor exhaust leak due to one of the studs breaking off. I only have 1 stud holding the exhaust pipe to the head. I did in fact tighten the remaining stud down ever so slightly..... I'm wondering "IF" when I slightly tighten the one remaining stud. Maybe that is causing the issue?
And yes it got WAY louder and made the exhaust leak worse.
Maybe blown a seal?
I'm at a total loss. Please any help would be great, before I start spending a lot of money trying to chase this down.
