In an effort to keep my alukit cool at WOT I decided to swap out my stock 3-wire ignition system for this A55 CID + parmakit, yay ignition curve.
Unfortunately, I no longer have brake lights. I believe the brake lights were powered off the blue wire on my old 3-wire stator.
What are my options as far as powering my brake lights? If I run them off my lighting coil then my head light dims dramatically when I engage the breaks (this happened when I swapped a 3-wire stator for a 2-wire stator on an older a3). Can I run the brake light off my ignition coil? Would that necessitate an additional voltage regulator between the ignition coil, the brake light and the CID box? I've looked through the A55 wiring diagrams but can't seem to find the secret...
Any input is appreciated, thanks in advance
