Re: 78 Maxi Tail Light Gremlin
You can use a 9v transistor battery. First verify the bulb and battery are good by placing the bulb directly across the battery terminals.
Put the bulb back in the socket. Remove the gray and the brown wires from the terminal strip that go to the tail light and place them on the battery terminals to test the entire circuit.
  78 Maxi Tail Light GremlinTopic by: Seth B Seth B 04/15/19 02:26PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 02:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 03:21PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 03:33PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 04:39PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 04:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 05:36PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 05:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 07:35PM
  Re: 78 Maxi Tail Light GremlinRe: Aaron Blair Aaron Blair 04/15/19 07:56PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 08:12PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 08:23PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/16/19 07:42PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/16/19 09:46PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/16/19 11:55PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/18/19 10:55AM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 04/18/19 11:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/18/19 11:41AM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 04/18/19 12:25PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/18/19 11:21PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/18/19 11:48PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/18/19 11:57PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/19/19 10:00AM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/16/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 06:40PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/29/19 08:31PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 09:12PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/29/19 09:26PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 10:26PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/29/19 07:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 08:01PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/29/19 10:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 11:40PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 12:04AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 12:16AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 11:25AM
  Re: 78 Maxi Tail Light GremlinroundsRe: P D P D 04/30/19 11:54AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 02:40PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 04:01PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 04:11PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 04:23PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 05:10PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 07:41PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 01:19PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 01:30PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 11:58AM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 04:19PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 04:36PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 04:46PM
  Re: 78 Maxi Tail Light GremlinRe: Richard Eberline Richard Eberline 04/30/19 06:14PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 07:16PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 07:30PM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 04/30/19 09:06PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 11:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:00AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:17AM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 05/01/19 04:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 10:15AM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 05/01/19 01:02PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 02:05PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 06:44PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 08:12PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/09/19 09:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 10:08PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 11:30PM
  Re: 78 Maxi Tail Light GremlinRe: Aaron Blair Aaron Blair 05/13/19 10:22PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 10:42PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 10:54PM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 05/14/19 09:07AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/14/19 10:41AM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 07:27AM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 08:42AM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 05/10/19 02:05PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/10/19 12:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/10/19 01:00PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/10/19 01:02PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 05/10/19 02:21PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 08:09AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/11/19 12:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 01:59PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 02:10PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 07:30PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 05/13/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 08:27PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 09:18PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 09:39AM
