Re: 78 Maxi Tail Light Gremlin
Probably Fred /
> Seth B Wrote:
> > Ken Roff Wrote:
> > The ground is through the fender likein 3 wire system,
> > One wire is tail light, ground is fender,
> > One wire brake light, other is fender,
> > All brown wires need to be connected to frame including brown wire to
> > frame by buss block !
> There is three wires coming off the back of the taillight. Grey,
> blue/green, and brown. All three wires connect at the wiring block. the
> brown wire does not ground at fender, but at wiring block then directly
> to HT coil bracket.
> The brown wire from the taillight goes:
> Taillight >> wiring block >> engine case.
> It does not ground thru fender.
You may have the pre 1978 dreaded five wire system/Stator not six wire installed
All my bikes have 6 wire Stator and harness and do not have ground wire to tail light from buss just a little brown wire that goes to fender tail light mounting bolt to taillight, there should only be a gray and (blue I believe?) that goes to the tail light from buss and tail light is grounded through fender and that little brown fender wire (edited)
  78 Maxi Tail Light GremlinTopic by: Seth B Seth B 04/15/19 02:26PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 02:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 03:21PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 03:33PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 04:39PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 04:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 05:36PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 05:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 07:35PM
  Re: 78 Maxi Tail Light GremlinRe: Aaron Blair Aaron Blair 04/15/19 07:56PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 08:12PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/15/19 08:23PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/16/19 07:42PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/16/19 09:46PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/16/19 11:55PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/18/19 10:55AM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 04/18/19 11:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/18/19 11:41AM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 04/18/19 12:25PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/15/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/18/19 11:21PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/18/19 11:48PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/18/19 11:57PM
  Re: 78 Maxi Tail Light GremlinRe: Hoarder Erik Hoarder Erik 04/19/19 10:00AM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/16/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 06:40PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/29/19 08:31PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 09:12PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/29/19 09:26PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 10:26PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/29/19 07:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 08:01PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 04/29/19 10:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/29/19 11:40PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 12:04AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 12:16AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 11:25AM
  Re: 78 Maxi Tail Light GremlinroundsRe: P D P D 04/30/19 11:54AM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 02:40PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 04:01PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 04:11PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 04:23PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Probably Fred Probably Fred 04/30/19 05:10PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 07:41PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Seth B Seth B 04/30/19 01:19PM
  Re: 78 Maxi Tail Light GremlinroundsRe: Mike Boyd Mike Boyd 04/30/19 01:30PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 11:58AM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 04:19PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 04:36PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 04/30/19 04:46PM
  Re: 78 Maxi Tail Light GremlinRe: Richard Eberline Richard Eberline 04/30/19 06:14PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 07:16PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 07:30PM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 04/30/19 09:06PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 04/30/19 11:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:00AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 12:17AM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 05/01/19 04:06AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 10:15AM
  Re: 78 Maxi Tail Light GremlinRe: Probably Fred Probably Fred 05/01/19 01:02PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/01/19 02:05PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 06:44PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 08:12PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/09/19 09:41PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 10:08PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/09/19 11:30PM
  Re: 78 Maxi Tail Light GremlinRe: Aaron Blair Aaron Blair 05/13/19 10:22PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 10:42PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 10:54PM
  Re: 78 Maxi Tail Light GremlinRe: P D P D 05/14/19 09:07AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/14/19 10:41AM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 07:27AM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/14/19 08:42AM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 05/10/19 02:05PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/10/19 12:52PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/10/19 01:00PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/10/19 01:02PM
  Re: 78 Maxi Tail Light GremlinRe: pat splat pat splat 05/10/19 02:21PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 08:09AM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/11/19 12:57PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 01:59PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 02:10PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 07:30PM
  Re: 78 Maxi Tail Light GremlinRe: Mike Boyd Mike Boyd 05/13/19 08:15PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 08:27PM
  Re: 78 Maxi Tail Light GremlinRe: Seth B Seth B 05/13/19 09:18PM
  Re: 78 Maxi Tail Light GremlinRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 05/11/19 09:39AM
