The head doesn't look bad. What sandpaper grit did you end with?
You didn't show the cylinder. Also the performance head on amazon was about 30.00 Id probably start there. Also use a torque wrench to torque it to specs. I gotta do that check soon. I'm almost certain my problem is on the intake manifold.
