Re: Moped Stops Running After 5 min
Don Ohio /
> Derek from black pipes moped gang Wrote:
> Could be that the gas isn’t flowing fast enough due to blockage in the
> fuel system. So when you start it the bowl is full of gas and slowly
> runs out as you ride. Cleaning your fuel system is cheap and easy, I’d
> start there.
^ This,per Ken Roff's advice also. even if it isn't the problem, it is really good practice.
  Moped Stops Running After 5 minTopic by: Austin Schilb Austin Schilb 04/12/19 01:17PM
  Re: Moped Stops Running After 5 minRe: Richard Eberline Richard Eberline 04/12/19 01:37PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/13/19 10:47AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/13/19 04:58PM
  Re: Moped Stops Running After 5 minRe: Seth B Seth B 04/12/19 01:48PM
  Re: Moped Stops Running After 5 minRe: Probably Fred Probably Fred 04/12/19 05:28PM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/12/19 08:17PM
  Re: Moped Stops Running After 5 minRe: kevin Smellaflange kevin Smellaflange 04/14/19 05:00PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/15/19 10:18AM
  Re: Moped Stops Running After 5 minRe: P D P D 04/15/19 11:38AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/15/19 02:02PM
  Re: Moped Stops Running After 5 minRe: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 04/18/19 02:11AM
  Re: Moped Stops Running After 5 minRe: Don Ohio Don Ohio 04/18/19 02:40PM
  Re: Moped Stops Running After 5 minRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/21/19 05:14PM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/26/19 03:04AM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 05/06/19 11:07AM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/10/19 02:15AM
  Re: Moped Stops Running After 5 minRe: Born to be WillD Born to be WillD 05/06/19 12:23PM
