Re: Moped Stops Running After 5 min
derek from black pipes moped gang 🌧 /
Could be that the gas isn’t flowing fast enough due to blockage in the fuel system. So when you start it the bowl is full of gas and slowly runs out as you ride. Cleaning your fuel system is cheap and easy, I’d start there.
  Moped Stops Running After 5 minTopic by: Austin Schilb Austin Schilb 04/12/19 01:17PM
  Re: Moped Stops Running After 5 minRe: Richard Eberline Richard Eberline 04/12/19 01:37PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/13/19 10:47AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/13/19 04:58PM
  Re: Moped Stops Running After 5 minRe: Seth B Seth B 04/12/19 01:48PM
  Re: Moped Stops Running After 5 minRe: Probably Fred Probably Fred 04/12/19 05:28PM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/12/19 08:17PM
  Re: Moped Stops Running After 5 minRe: kevin Smellaflange kevin Smellaflange 04/14/19 05:00PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/15/19 10:18AM
  Re: Moped Stops Running After 5 minRe: P D P D 04/15/19 11:38AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/15/19 02:02PM
  Re: Moped Stops Running After 5 minRe: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 04/18/19 02:11AM
  Re: Moped Stops Running After 5 minRe: Don Ohio Don Ohio 04/18/19 02:40PM
  Re: Moped Stops Running After 5 minRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/21/19 05:14PM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/26/19 03:04AM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 05/06/19 11:07AM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/10/19 02:15AM
  Re: Moped Stops Running After 5 minRe: Born to be WillD Born to be WillD 05/06/19 12:23PM
