Re: Moped Stops Running After 5 min
Probably Fred /
> Austin Schilb Wrote:
> Hi all,
> My name is Austin and I'm looking to get my 1984 Puch Maxi to stop dying
> on me. She starts up nice, idles fine, and rides okay for the first five
> minutes. After that, I'll be at full throttle and a complete standstill
> on flat ground. I have yet to clean the carb and exhaust, but I'm
> assuming that those aren't the source of my problem given that she will
> run at first. I'm guessing this has something to do with the condenser?
> Is there a good way to check that that is what's wrong?
Clean the carb fuel filter fuel petcock before you even think of the ignition
  Moped Stops Running After 5 minTopic by: Austin Schilb Austin Schilb 04/12/19 01:17PM
  Re: Moped Stops Running After 5 minRe: Richard Eberline Richard Eberline 04/12/19 01:37PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/13/19 10:47AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/13/19 04:58PM
  Re: Moped Stops Running After 5 minRe: Seth B Seth B 04/12/19 01:48PM
  Re: Moped Stops Running After 5 minRe: Probably Fred Probably Fred 04/12/19 05:28PM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/12/19 08:17PM
  Re: Moped Stops Running After 5 minRe: kevin Smellaflange kevin Smellaflange 04/14/19 05:00PM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 04/15/19 10:18AM
  Re: Moped Stops Running After 5 minRe: P D P D 04/15/19 11:38AM
  Re: Moped Stops Running After 5 minRe: Den 23 Den 23 04/15/19 02:02PM
  Re: Moped Stops Running After 5 minRe: derek from black pipes moped gang 🌧 derek from black pipes moped gang 🌧 04/18/19 02:11AM
  Re: Moped Stops Running After 5 minRe: Don Ohio Don Ohio 04/18/19 02:40PM
  Re: Moped Stops Running After 5 minRe: Blaine- The artist formerly known as Plumber Crack "(OFMC)" Blaine- The artist formerly known as Plumber Crack "(OFMC)" 04/21/19 05:14PM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 04/26/19 03:04AM
  Re: Moped Stops Running After 5 minRe: Austin Schilb Austin Schilb 05/06/19 11:07AM
  Re: Moped Stops Running After 5 minRe: ♣Slew Foot♣ ♣Slew Foot♣ 05/10/19 02:15AM
  Re: Moped Stops Running After 5 minRe: Born to be WillD Born to be WillD 05/06/19 12:23PM
