exactly, the no spark is hidden in the rear fender corroded wires that r tucked in the bead. check this first or go down the longer path.
Seth B Wrote:
> > Tim Taylor Wrote:
> > Thanks Dirty. You're a pal. Now I can start looking into the
> > spark......
> That's the easy part. If you don't have spark, check your tail light
> bulb. Ignition grounds thru your brake light. If your brake light is
> blown or missing, (or the wire is damaged inside the rear fender, like
> mine was), you won't have spark.
