AARON: with the belt on= bad. With the belt off = bad. With the belt AND variator off = good. The variator is binding against the frame. DIRTY: I believe that is good advice. It is strange that the second diagram (above) shows no spacer. I don't understand part #108 -- it seems that would prevent the bush (#104) from sliding into the inner pulley (#105). LES, I believe spacer #104 is pressed into the pulley, but I don't see the #106 spacer. S0.....figuring I need the spacer, any idea where to get one? Again, thanks everybody.
Re: 1978 Vespa Bravo variator binding. Missing parts?
