Re: 1978 Vespa Bravo variator binding. Missing parts?
Tim Taylor /
AARON: with the belt on= bad. With the belt off = bad. With the belt AND variator off = good. The variator is binding against the frame. DIRTY: I believe that is good advice. It is strange that the second diagram (above) shows no spacer. I don't understand part #108 -- it seems that would prevent the bush (#104) from sliding into the inner pulley (#105). LES, I believe spacer #104 is pressed into the pulley, but I don't see the #106 spacer. S0.....figuring I need the spacer, any idea where to get one? Again, thanks everybody.
  1978 Vespa Bravo variator binding. Missing parts?Topic by: Tim Taylor Tim Taylor 04/11/19 12:32AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 12:42AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 02:23AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Aaron Blair Aaron Blair 04/11/19 06:36AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Dirty30 Dillon Dirty30 Dillon 04/11/19 08:55AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Les B. Les B. 04/11/19 10:22AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Dirty30 Dillon Dirty30 Dillon 04/11/19 11:47AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 11:35AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 11:57AM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Seth B Seth B 04/11/19 12:04PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 12:13PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Seth B Seth B 04/11/19 12:46PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: pat splat pat splat 04/11/19 01:25PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Tim Taylor Tim Taylor 04/11/19 12:17PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Les B. Les B. 04/11/19 12:54PM
  Re: 1978 Vespa Bravo variator binding. Missing parts?Re: Graham Motzing Graham Motzing 04/11/19 01:19PM
