Re: QT50 70cc Malossi Kit Sticking?
Big JD /
Nailed it (pun intended).
Sure enough the base of the piston was impacting the case. Shaved off about a mm and I'm golden.
Thanks all. I kept staring at the poor machining on the block assuming it to be the culprit.
