Tomos Targa LX Fork Lock Replacement
I bought a (Tomos OEM Fork Lock and Key Set for post 2003 models - 229293) from Moped Division, but when I went to replace it I realized that the fork lock mounting area is different than what I expected. There is no small set screw, or broken screw that is used to set the locking mechanism in place like I have seen in most materials on the Tomos fork locks.
Instead there is a narrow channel running along the outside bottom of the lock housing. I have not found anything else around the outside of the lock housing.
It looks like the lock housing is filled with a solid plug of copper, that has been partially drilled through(see pic). This does not look like it was originally a functioning lock.
Has anyone had any experience with this, or know of any way I can get the original copper plug out and what fork lock replacement would work? I am desperate, cant find anything on this particular problem. Thanks in advance.
