Re: Garelli SSXL stalls after riding for 15 minutes
♣Slew Foot♣ /
get it hot get it to stall check your compression with a meter then you can see if it's a seal leak or maybe it could even be ovaled cylinder or blow by on piston
Try running your truce 2 stroke oil with Marvel Mystery Oil in your gas once a month usually it cleans out all your crap and it also will swell your seals you can even put it in your tranny it swells the seals and the rubber clutch or cork or leather
oh yeah make sure your gas cap vent is working and you have your two stroke oil line plugged if you're running premix
