Re: Run & done
Kasey OKeefe /
Thank you all very much for your time it fires right up it runs for like about a minute and a have the fuel petcock is on one position
It goes strong then it starts to lose power in a minute or 2 and will start to die down and bog. Until completely shutting off if I try to kick it over it won’t start and then I put it from run position to off and walk with it for a minute and re kick it will start I drove it 13 miles thru Los Angeles without an air filter on the carburetor because it fell off I’m wondering if that might’ve had something to do with it at lost parrot for something did get in there I ordered a new air filter it just arrived any thoughts thank you all for your time
