Re: Sachs Balboa wants to go backwards
Born to be WillD /
Timing timing timing timing your timing is backwards and you need to check it, pull the flywheel off. Probably sheared key yep. Doesnt take much, if you're off on timing it can start in the opposite direction and being 2 stroke it operate same either direction... old 2 stroke cars used to just start the engine backward as the reverse
