Re: Tomos Electric Woes
♣Slew Foot♣ /
That cdi box bad two poles a pos a and negative the Box that is the regulator is missing the ground wire the other is the trigger the ground wire go straight to the frame closer to the engine you join all your grounds and mount them near the engine rear not on the back of the frame near the Tail it makes the dry ground travel too far and works like a kilchers switch ground the regulator and run the negative Port of the high-tension coil or CDI box grounded right at the engine on the frame that is if it's an a359 a55 that had the other triggered CDI which would have four wires and it wouldn't be duplicate power and Lighting some kinetics had that that is a kinetic box the old ones like an A35 will work with that whereas the a55 need the trigger or be modified with an A35 stator and flywheel if you have an electric start it's an it's in a five five
