I picked up what I belovr to be a 80s safari turbo with a minarelli engine. It kicks over and has spark but I can't seem to get it running. I'm thinking the wires look tampered with. Any help is appreciated as I'm at a lost
Only thing I've found is the Safari Fox wiring diagram here:
https://drive.google.com/drive/folders/1iKjElUueJEDn3pkYQiK2uBjnghu1wozb
page 14 or so
Thanks. I have that pdf downloaded also. The wires coming from the engine are blue, then yellow then blue with black stripe.
one is 6vac lights
one is 12vac ignition
one is ground to the kill switch. and tail light
Tail light has a 6.5 ohm resister wired in, both lights need to work
Ok I'll check it out in the afternoon tomorrow. Thanks
Does anyone know what model this is
