Re: 1980 qt50 won't start
Jack Rutherford /
yes the right tools and a little bit of time.
piston stop
flywheel puller
and an inch/pound torque wrench
Might as well change that seal while you are at it.
or get all the seals at once
get a big washer that will fit over the crank and a piece of pvc pipe that will do the same. I like to use Yamabond on that side on the outside of the seal. Place washer over seal and the use the pipe and a rubber mallet to tap it in place. Seat it flush with the case. Don't strip your stator screws either. Get a blunt tip screwdriver. They will strip otherwise. they're always in their good.
button it up and enjoy the ride. (edited)
  1980 qt50 won't startTopic by: Robbie Cockrell Robbie Cockrell 03/26/19 09:43AM
  Re: 1980 qt50 won't startRe: Louis Brunskill Louis Brunskill 03/26/19 10:02AM
  Re: 1980 qt50 won't startRe: Moped Lar Moped Lar 03/26/19 10:13AM
  Re: 1980 qt50 won't startRe: William Johnson William Johnson 03/26/19 11:19AM
  Re: 1980 qt50 won't startRe: Stephen Keller Stephen Keller 04/01/19 01:12AM
  Re: 1980 qt50 won't startRe: Arlie Endsley Arlie Endsley 04/03/19 11:36AM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 04/03/19 02:47PM
  Re: 1980 qt50 won't startRe: Arlie Endsley Arlie Endsley 04/03/19 11:58AM
  Re: 1980 qt50 won't startRe: Arlie Endsley Arlie Endsley 04/03/19 12:02PM
  Re: 1980 qt50 won't startRe: Brian G Brian G 04/03/19 12:49PM
  Re: 1980 qt50 won't startRe: Stephen Keller Stephen Keller 04/03/19 02:46PM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 03/26/19 12:43PM
  Re: 1980 qt50 won't startRe: Arlie Endsley Arlie Endsley 03/29/19 01:50PM
  Re: 1980 qt50 won't startRe: Brian G Brian G 03/29/19 10:39PM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 03/29/19 11:31PM
  Re: 1980 qt50 won't startRe: Brian G Brian G 03/30/19 12:53AM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 03/29/19 07:42PM
  Re: 1980 qt50 won't startRe: Angry Hipster Angry Hipster 03/30/19 08:24AM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 03/30/19 08:30AM
  Re: 1980 qt50 won't startRe: Rob LaFreniere Rob LaFreniere 04/01/19 02:17PM
  Re: 1980 qt50 won't startRe: Jack Rutherford Jack Rutherford 04/01/19 04:55PM
  Re: 1980 qt50 won't startRe: Rob LaFreniere Rob LaFreniere 04/01/19 05:01PM
  Re: 1980 qt50 won't startRe: Robbie Cockrell Robbie Cockrell 06/03/19 06:22PM
  Re: 1980 qt50 won't startRe: Brian G Brian G 06/03/19 06:24PM
