Re: Electrical help
Aaron Blair /
would look like a braided metal cable. usually somewhat flat, connecting the headset to the frame...
you have voltage to the thingys, the question is where you are losing the ground,, running current through headset bearings is sketchy at best...maybe tomos runs the ground through the harness.....idk, havent had the time to look. im drunk right now
only ever had 1 tomos. ...have you opened up the switch housing and looked around for weird stuffs. corrosion ect?
