Electrical help
Got my 2010 TOMOS Sprint DEMON SPAWN moped running...But now the headlight is dim, the horn, and kill switch still don't work...Now here's the kicker if I flip the ground switch to on, on the handlebars my lights turn on (brightly), and the horn works, just no kill switch still?!?!?!?!? What the hell is going on here!?!?!?
Re: Electrical help
picture of ground switch please.
Re: Electrical help
Quentin Moon /
Re: Electrical help
Dude, totally a ground issue.when you press the horn ur giving the headlight a path to ground...
Looky here.
http://www.myronsmopeds.com/wp-content/uploads/2008/04/Tomos-Wiring-2008-11+-SprintSTLX-100dpi.jpg
Re: Electrical help
Do tomos have a ground strap on the headset?
Re: Electrical help
Quentin Moon /
I'm not sure what that is? Or if I do or don't. What's it kook like?
Re: Electrical help
would look like a braided metal cable. usually somewhat flat, connecting the headset to the frame...
you have voltage to the thingys, the question is where you are losing the ground,, running current through headset bearings is sketchy at best...maybe tomos runs the ground through the harness.....idk, havent had the time to look. im drunk right now
only ever had 1 tomos. ...have you opened up the switch housing and looked around for weird stuffs. corrosion ect?
Re: Electrical help
Quentin Moon /
Yeah I did have the switch open when I painted the handlebars, could that be part of the issue? Thanks again for the help!
Re: Electrical help
♣Slew Foot♣ /
Kill depends on ground from handlebars as do brake sensors.
Re: Electrical help
the paint may be your problem...you never said you painted the bars lol..
Re: Electrical help
Quentin Moon /
Sorry, yeah I had to they were pretty rough!
Re: Electrical help
Quentin Moon /
Okay got the kill switch, taillight/brake light/switch, and engine running again, but now the headlight is giving me sxxt. It obviously has to have power and ground to work, but when I ground it, getting it to turn on, the engine dies?!?!?! Thoughts?!?!? Thanks again!!
Re: Electrical help
I know this is an obvious answer but are you revving the engine? The headlights get brighter as the rpm rises.
Re: Electrical help
Quentin Moon /
My headlight turns on when my bike is kicked over and runs constantly. I think that may have something to do with the way my bike was rewired by it's previous owner.
Re: Electrical help
That's what it's SUPPOSED to do,Quentin. Headlight should always be on with modern Tomos. UNLESS you have an off switch, which my 05 StreetMate doesn't. You can make it go off by putting the switch between HI and LO beam positions.
Re: Electrical help
Quentin Moon /
Oh I know!!! :-):-) I thought someone had asked if it had been switched off. But yeah sorry that was on a different thread. (edited)
